Can't get spark from my cpr setup
jaekgood23
Post by jaekgood23 »
I'm having issues with getting my cpr to fire also.....I went through all the trouble shooting issues with no success....get all the correct lights just as they say I should and I tried a brand new coil pack with no success..i also tried cleaning the ground on the thermostat to make sure....yes I have a rectangle ecu with the q37 installed...I have tried more then one ecu...even had a performance shop wire it up for me.....pleasseeeee help!
Re: Can't get spark from my cpr setup
In the past all the CPR problems have come down to spark plugs, distributors, ECUs and wiring.
The first step is to tell us what spark plugs, ECU, software version & S300 serial number you have. Is the distributor genuine Honda?
Has the wiring been altered in any way? Can you post photos of the CPR power, ground & ECU connection, then the CPR main ground and the distributor connector.
