B16 turbo ID1000 cc
Dennisc
B16 turbo ID1000 cc
Post by Dennisc »
Hello guys, I need a basemap for my car, I need to start the engine and know everything works.
I would like to drive it straight to my tuner.
I was also thinking to maybe not connect my turbo to my inlet just yet so I don't build up any boost in my engine and i would be able to safely drive it to the tuner this way? Or is this a bad idea?
(Would I need a NA basemap then with ID1000 injectors and other things...?)
Specs:
Setup engine;
B16a1
Stock sleeves/ crank
Eagle rods
CP pistons (9.0:1)
Supertech valves/springs/retainers
b18c4 cams with AEM Cam gears
B18C6 inlet with AEM fuel rail & FPR
Turbo:
turbonetics T3 super 60 with full 3" exhaust & exhaust
fuel;
255lph Walbro
1000 cc Injector dynamics
Electronics;
Hondata S300 V2 (with boost by gear available)
Hondata 4 bar map sensor
AEM uego wideband / truboost / oil temp / oil pressure
Thanks in advance guys!
Re: B16 turbo ID1000 cc
That will over spin the turbo and is a bad idea. Talk to your tuner about a basemap to get to the dyno.
