2002 civic with 2013 civic si k24z7 crank sensor?
Atc350x
Post by Atc350x »
Hey, I have a 2002 civic I've spent hours doing this swap used rear custom mount and used 36mm hubs for the axles also have the prl intake manifold adapter kit with an 8th gen intake manifold and hybrid racing throttle body, digital Dakota box only thing I ran accross was the knock sensor I did re wire it for the other location I am using a 2002 rsx engine harness (changed all sensors over except for crank shaft sensor) I heard these crank shaft sensors pulse 50 times instead of 10 I was going to use kpro but I geuss that wouldn't work for me. I was curious if I could use a k24 cog off an older k24 engine and maybe customize the timing cover or even if I could use an older k24 crankshaft?
Re: 2002 civic with 2013 civic si k24z7 crank sensor?
This will not work. You will need to use a compatible engine and use a K-Pro. The FlashPro is not designed for engine swaps.
Atc350x
Post by Atc350x »
So I couldn't use the cog off a 2010 tsx? Or a crank?
No, these are not interchangeable.
