urgent! need basemap for ct-e supercharged stock 2014 si
jstingley
Post by jstingley »
hi srry this is urgent im a sitting duck the company sent me a base map but it says map wont work on a 2014 flash pro y are they not the same i need a map now also this is with 550 dw injectors
Re: urgent! need basemap for ct-e supercharged stock 2014 si
Call CT and they should be able to send you the correct calibration.
