Wideband Input Question
gorechylde
Post by gorechylde »
I have an Innovate MTX-L and have wired the analog wideband signal to Analog 0 of my S300 V3. I have the narrowband signal wired to Analog 1. Will this setup work properly or do I need to wire them to pins on the engine harness?
The "Closed Loop Advanced" only offers D14, D10, D12, and B6 as input sources. Is there a setting I can change to have it read a wideband signal from the Analog Inputs on the S300 or is it doing that already?
I currently have my stock O2 sensor installed in addition to the Innovate Wideband.
Thanks for your time.
Re: Wideband Input Question
You need to go to the analog inputs tab of parameters. You cannot run closed loop from this, but you can datalog from it. You can only run closed loop using the ECU inputs for the wideband.
gorechylde
Gotcha. Thanks Spunkster.
Since I'm still running my stock O2, would you say it's necessary for me to re-pin to the ECU or should I leave it as it is and tune Open Loop from the wideband and run closed loop from stock O2?
Can I still use my Lambda Table Overlay if the wideband isn't pinned directly to the ECU?
You do not need the stock narrowband. I would just wire the Wideband analog signal to the ECU and run closed loop form the wideband signal.
gorechylde
Will do. Thanks Spunkster.
