Slightly jerks @2000 rpms with Rotrex and MAF-Cal!
R-12914
Post by R-12914 »
Hi,
I have a question which reads as follows:
I currently have the MAF calibration on my ECU.
I noticed at about 2000 rpms when I push the throttle more or less strongly (independent of which gear is in), or if I at about 2000 rpms the accelerator then kick too sudden, the car jerks slightly, as if I had minimal misfires.
This is only at round about 2000 rpms, not at less or higher rpms!
If the engine has more temperature, this phenomenon is somewhat less strong, but still present.
What could it be your opinion, how can I find out to what it is or how can I fix it?
Thank you so much for your reply and regards,
Matthias
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Slightly jerks @2000 rpms with Rotrex and MAF-Cal!
Has the is vehicle been properly tuned on the dyno? Have you discussed this with your tuner?
R-12914
Post by R-12914 »
The Engine/Car was tuned on the street by Vit.
BTW: The throttle body is before the supercharger!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
