"Create Boost Tables" action
gorechylde
Post by gorechylde »
I've noticed that my "create boost tables" setting from the edit menu seems to reset itself every time I close SManager. Do I have to create boost tables every time I open SManager or is it like a table adjustment that only needs to be performed once?
Thanks for your time.
Re: "Create Boost Tables" action
It is a function that modified the fuel/ignition tables to generate a starting point for boost tuning. You only need to use it once, but the tables will need further refinement.
