remove maf sensor and cruise control+cdb
beppe
Post by beppe »
hi to all
i need An information
when i use map base with iat sensor instead of maf sensor how can i do continue using Cruise control......i se e the check on flaspro manager......there's any other parameter to set for working Cruise control with ita sensor
thanks
Re: remove AFM sensor and cruise control+cdb
Cruise control should have nothing to do with this.
beppe
Post by beppe »
Yesterday i do a iat base map with software release 1.8.3
i have enabled check cruise control but cruise control don't working.....
my friend have the map tuned by vitviper with latest beta release 1.9.1 and his cruise control working perfect
another my friend whit map with rel 1.8.3 don't working cruise control
my question is:
is only the release beta 1.9.1 that working done cruise control or there's something that i don't know to do in flashpro manager to check?
R-12914
Post by R-12914 »
Do you have add the correct "gear ratios" under "Calibration" into your Map?
Post your Cal, than i can help you!
Your car is a FN2?
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
beppe
Post by beppe »
thanks very much....i have corrected gear ratios for fn2 euro and now cruise control working perfect
thanks a lot
