remove maf sensor and cruise control+cdb
Posted: Sun Aug 10, 2014 8:55 am
by beppe
hi to all
i need An information
when i use map base with iat sensor instead of maf sensor how can i do continue using Cruise control......i se e the check on flaspro manager......there's any other parameter to set for working Cruise control with ita sensor
thanks
Re: remove AFM sensor and cruise control+cdb
Posted: Mon Aug 11, 2014 9:49 am
Cruise control should have nothing to do with this.
Posted: Tue Aug 12, 2014 3:49 am
by beppe
Yesterday i do a iat base map with software release 1.8.3
i have enabled check cruise control but cruise control don't working.....
my friend have the map tuned by vitviper with latest beta release 1.9.1 and his cruise control working perfect
another my friend whit map with rel 1.8.3 don't working cruise control
my question is:
is only the release beta 1.9.1 that working done cruise control or there's something that i don't know to do in flashpro manager to check?
Posted: Tue Aug 12, 2014 6:28 am
by R-12914
Do you have add the correct "gear ratios" under "Calibration" into your Map?
Post your Cal, than i can help you!
Your car is a FN2?
Posted: Wed Aug 13, 2014 12:56 pm
by beppe
thanks very much....i have corrected gear ratios for fn2 euro and now cruise control working perfect
thanks a lot
