Check engine & battery light on, how to delete it?
TAOTAO
Post by TAOTAO »
I have EU CTR with KPRO (PRA ECU), the car run fine, today I drive it and get to the redline (stock 8100 RPM), stay there few sec and continue, after that the engine & battery light on and from time to time the EPS light, the car look like running fine but the engine & battery light on are still there, I try to delete DTC, but its don't help, the same code (EVAP etc) still go up.
I need to erase the ECU or disconnected the battery ?
Thanks ahead,
Idan
Re: Check engine & battery light on, how to delete it?
This sounds like something you will probably need to have a Honda dealer take a look at. It may have to do with the alternator or charging system.
TAOTAO
Post by TAOTAO »
The dealer is out of my country, there is some checking that I can do on the ECU itself ? or I need to check the alternator charging etc ?
Look at the factory service manual for troubleshooting this. You really should try to avoid driving until this can get checked out and fixed.
TAOTAO
Post by TAOTAO »
The fuse of the alternator was burned, replace it (10a fuse locate under the steering wheel), the battery light go off, disconnect the battery for 20-30 sec, the engine light off, all look fine.
You know maybe what can be the cause for that ? I check the alternator and the charging system all look fine and stable.
This is something you really should talk to a shop or dealership about. It has nothing to do with the ECU or the Hondata system. There is obviously a problem of some kind for a fuse to blow.
TAOTAO
Post by TAOTAO »
OK, find the issue, the wiring of the rear lambda sensor was exposed, So I take the sensor off, how can I disable it on the K manager ?
Thanks.
Under the closed loop tab in parameters.
