S300 B16A-1 PROBLEM
LELAND25
S300 B16A-1 PROBLEM
Post by LELAND25 »
I have a B16A-1 in my 89 CRX with various Skunk2 add on; now I have a P30 ECU w/ S300 program. The engine will turn but will not crank-up. The relay switch was replaced and still will not start. The shop explained that the relay switch is being tripped. Just received a replacement ECU/S300
from the vendor -Trackmasters- and still the problem continues. Can anyone please HELP!
Thanks,
James
Re: S300 B16A-1 PROBLEM
It does not sound like a problem with the ECU or s300. It sounds more like a mechanical or wiring related issue. Did it ever work with this setup?
LELAND25
Post by LELAND25 »
Thanks for your response. Yes, I actually had the my CRX back several weeks ago and for a
couple of days it ran just fine. Then, leaving work the engine would not crank-up, ...it would
turn but not start. After numerous attempts and pushing the car a short distance, it started
right up. I drove right back to the shop and that was the last time it would start. Thanks
