Help, failure ECU pin B2. I have no signal.
roma
Post by roma »
I need your support. I'm from Mexico and I have a 08 Civic SI turbo. I had problems with my boost control solenoid, it was damaged and then replaced. The deal is I'm not getting signal from the ECU (pin B2). Any suggestions? is a good idea to send the ECU to be repaired with Hondata?
Thank you very much for your help.
-Roma.
Re: Help, failure ECU pin B2. I have no signal.
If the output on the ECU has been damaged then you will need to return your ECU to stock and unlock the FlashPro and get a new ECU and then lock the FlashPro to the new ECU. We cannot repair damaged ECUs.
roma
Post by roma »
Spunkster wrote:If the output on the ECU has been damaged then you will need to return your ECU to stock and unlock the FlashPro and get a new ECU and then lock the FlashPro to the new ECU. We cannot repair damaged ECUs.
Ok. Bad news :( so, when I get a new ECU I'll need new keys too?
The HOnda dealer will also have to match your keys and immobilizer to the new ECU. They should know what to do.
roma
Post by roma »
Ok thank you very much for your support (Y). One more thing, you know who could sell an ECU in good condition?
roma
Post by roma »
If I install a new ECU, the millage that was deleted? Because I had very little (19,000 mi). Thank you very much, I really appreciate your support.
-Roma.
The ECU has nothing to do with the odometer reading.
