device not pairing
spewin
device not pairing
Post by spewin »
Hi
I just recently installed the s300 v3
Paired it with the phone. Though when I open the hondata app it says device not paired.
I have a HTC one m8. Android software 4.4.3
Am I doing something wrong?
Any help would be great.
Regards
Re: device not pairing
Do not use the pairing procedure in the phone. Just use the lightning bolt to connect in the App.
There may also be an issue with connecting on the HTC phones, somehow they have changed how Bluetooth works.
spewin
Post by spewin »
Now it says connection failed if I do that way.
Any more ideas on getting it to work?
Feels like such a waste not working.
Thabks
change the PIN# in Smanager to 0000, then try to connect again
spewin
Post by spewin »
All good now thank you for that info!
cam6222
Post by cam6222 »
Im also facing same problem. I already put passcode follow my s300 board number. But in hondata apps i the device is not pairing. Please help
Mrs Autoparts @ Honda Parts Malaysia
What device do you have? With iOS you don't pair.
"passcode follow my s300 board number' - use 0000 or 1234 as some devices don't allow more than 4 characters, or only use 0000 or 1234.
cam6222
Post by cam6222 »
Hondata wrote:What device do you have? With iOS you don't pair.
I use android. Samsung galaxy note 4. With dash command i can link. But hondata apps i already connect. But the apps not pairing
rdxchris710
Post by rdxchris710 »
I have been running into issues with the app not connecting to the FP. Sometimes i need to restart my phone, close all other apps. I never just turn it on and it connects.
2007 Acura RDX
DW 800cc injectors / cpe intake / turbonetics raptor bypass
Flashpro / VIT Viper tuned
Rv-6 3.5-3" exhaust
What is the exact brand and model phone and what version of android is it using?
rdxchris710
Its a Motorola X android 4.4.4. I have had it crash a few times during normal driving and have sent the reports via google. The slowness in logging I can deal with but random disconnects and I am unable to reconnect. I usually have to unhook the FP and replug it in. Ive tried to reboot the phone, shut Bluetooth on and off close and reopen the app and get a connection failed .
2007 Acura RDX
Rv-6 3.5-3" exhaust
Carlion
Post by Carlion »
Spunkster wrote:change the PIN# in Smanager to 0000, then try to connect again
Hi, having exactly the same issue. How do you change the pass code in Sanger. Where us Sanger?
Thanks,
Carlion.
Carlion
Post by Carlion »
Thanks,
Carlion.
Sorry, that should have read Smanager
In SManager, click the s300 button at the top and then go to the Bluetooth tab.
