2007+ South African Civic Type R
ecronic
Post by ecronic »
Hi All
I have a 2010 Civic Type R with Flashpro tuned. After the tune I realised that my stock shift lights don't work and the cruise control doesn't work on the 6th gear. Any idea if this is a bug on the software or is there an update going to be release or will it never be fixed?
I have returned the car to stock and everything starts working again so I'm sure this is happening due to the flashpro tune.
Please advise.
Thanks & Regards
Ecronic
civicRSA
Re: 2007+ South African Civic Type R
Post by civicRSA »
You just need to use the correct calibration.
Send me a pm I am a tuner in South Africa.
Post the calibration you are using
ecronic
Post by ecronic »
Spunkster wrote:Post the calibration you are using
Hi, this is the calibration I have on my car at the moment
Thanks & Regards
Ecronic
You are using a race based calibration, this is why those things are not working. You should use an AFM based calibration, you can still tune via MAP. The race calibrations are old an outdated and there is really no reason to use them.
ecronic
Post by ecronic »
Spunkster wrote:You are using a race based calibration, this is why those things are not working. You should use an AFM based calibration, you can still tune via MAP. The race calibrations are old an outdated and there is really no reason to use them.
Thanks for the reply.
Will let my tuner know. A question though... Is it possible to convert this calibration to AFM or do I have to do the full tune again?!
Thanks & Regards
Ecronic
You can try importing tables, but you may need to do some retuning.
