no spark
Egh22ahatch
no spark
Post by Egh22ahatch »
Ive been working on this for 2 days tried everything purple wire to A16 yellow red to A21 black ground to A23 POWER to A25 I got power ignition and synce but no spark pins on tach done properly watched YouTube video hundred times changed setting in s300 uploaded them and checked for Q37 in ecu its there im thinking my rywire harness might have something to do with it when goin to depin A16 it wasn't there also A22 wasn't there im lost im about to put it all back to my stock dizzy
crucian
Re: no spark
Post by crucian »
Do you have power to the coils? Check for power and ground at the coil terminals.
Egh22ahatch
Re: no spark
I got so frustrated I took it off put it back to stock can't believe 6 wires could cause such a nightmare im not knocking the product im sure I was doin something wrong but instructions and video was followed to a T ...maybe d17 coils dont work with cpr kit..ill give it another try once I get more time
Re: no spark
Did you try placing the spark plug in the coil and checking for spar outside of the engine. The spark plug does need to be grounded to do this.
Adotcruz24
Re: no spark
Post by Adotcruz24 »
All lights work. Car started like 3 days ago. When to start the car and nothing. I swap with CPR box with my friend and car starts. How does this box go bad soo fast? I plug my cpr box in his car and wont turn on but all lights work? Im guessing i have a bad cpr box but how? I didnt even put 50 miles in the build before the cpr box gave out?
