Fuel Trim
JS4KX
Fuel Trim
Post by JS4KX »
Hey guys, had a map file sent to me recently (the original tune, long story) but I see the Fuel trims is all at 0% example: overall fuel trim, crank fuel trim, throttle tip, cyl 1-4 and cold start... I know the overall fuel trim is compensated by a bigger input injector size, but I am more wondering if the crank, cold start, and throttle tip is suppose to be 0% as well... I am trying to get ahold of the tuner, but I know he's a busy guy so in the mean time, I figure I try and ask...
Thanks.
Re: Fuel Trim
That is something only you or your tuner could answer.
JS4KX
Re: Fuel Trim
Post by JS4KX »
Ok, thanks... will continue to try and get ahold of him...
So no one else can answer if any of there maps cranking, cold start, and throttle tips are at 0%?
