changin injectors?
htownhatch
changin injectors?
Post by htownhatch »
Right now i have precision 1000cc injectors, if i change to a different brand but the same size injector would i need a retune? also if i just replaced the injectors with the same exact ones would a retune be recommended?
Re: changin injectors?
IT all depends on if they have the same dead times and flow rates. You should make sure it is running safely before you really get on it.
