under wot app freezes
Egh22ahatch
Post by Egh22ahatch »
I got the app to work with my old HTC phone when entering the pin I got on the side of my s300 box everything works great but under wide open throttle app freezes in order to get it to work again I need to shut off the car and app and then restart and everything works fine until wot...im running resistor type plugs im thinking could possibly be my distributor ebay rebuilt with oem parts ...also under smanager where can I change the code to 0000? I looked everywhere
Re: under wot app freezes
It is electrical interference stopping the s300 to ECU communication. What wiring harness are you using? What grounds do you have? What spark plugs are you using?
Egh22ahatch
Rywire harness ngk resistor plugs bkr7e grounds are new clean attached to valve cover alternator bracket and transmission
How hard is it to use a stock harness?
The grounds positions don't include the thermostat housing?
Egh22ahatch
It would be very difficult to use stock harness I shaved all the holes in the bay where original harness went ...ecu ground is connected at the thermastate housing ...
It could be the distributor, grounds, wiring harness or ECU. If possible swap the ECU/s300 into another vehicle and test.
Egh22ahatch
Great idea thanks ill try it
Egh22ahatch
Why is it that only the app freezes under wot when data logging it doesn't freez just app does
Datalogging from a laptop is ok? That would still be a similar cause.
Egh22ahatch
No issues dataloging from a laptop
Is it any better with the lid to the ECU off?
Egh22ahatch
Ill try it with the lid to the ecu off just curious on why you want me to try that does that help dissipate heat? Info on the ecu p06 vtec added and BBG added all done by phearable. Net
It has more to do with interference and increasing the range of the Bluetooth radio. Heat would have nothing to do with this.
Egh22ahatch
With the ecu lid off and ecu on the floor it doesn't freez at all deff pumped about that I guess in the stock location covered by carpet ecu lid just can't read..what should I do to resolve this clear ecu cover new location?
The clear lid should help with this.
