AEM 4-Channel Wideband Air/Fuel UEGO Controller
Posted: Tue Sep 23, 2014 6:29 pm
by _Mozz_
Can I run the AEM 4-Channel Wideband Air/Fuel UEGO Controller with the FlashPro?
Re: AEM 4-Channel Wideband Air/Fuel UEGO Controller
Posted: Wed Sep 24, 2014 9:24 am
You will only be able to log one channel at a time as there is only one input available for wideband input.
Posted: Thu Sep 25, 2014 4:54 am
by _Mozz_
Thanks for the Reply.
Such a shame!! One step behind Kpro. . . We can not run ITBs, can not run 4-channel Wideband . . :-(
So, the only way to get acurate indivudual fuel tune for a Big Motor using FlashPro, would be to run parallel logs, with the AEM just there to monitor the individual AFR and then Correct it on the FUEL TRIM on FlashPro?
Posted: Thu Sep 25, 2014 9:21 am
You would have to switch the outputs each time you wanted to log a different cylinder.
