Target Lambda issue
djarmyssg
Target Lambda issue
Post by djarmyssg »
Ok, I have my IDLE Target Lamdba set to 15.7 in Kmanager. But no matter what I put in the input box. My ACTUAL Target AFCMD doesnt change from 14.7 at idle. I can set my "TARGET" to 21:1 and it will still show a command target of 14.7:1 and adjust my AFR to 14.7:1 via closed loop operation.
NOW with that being said.. I ALSO have an issue where when I'm in OPEN loop KManager "USED" to show my target AFR based on my "Lambda Overlay" Settings.... Low Load 15.7, medium load 12.7, and high load 11.5. But NOW... when I enter into highload..... the "Target" will still only show 12.5..... I never had these issues before... Is this something with the Beta Kmanager??? currently running 3.3.1.0....
Ideas??!?!?!?!
Re: Target Lambda issue
There is no beta KManager currently. What version are you using?
djarmyssg
Post by djarmyssg »
Sorry.. Currently running Kmanager Version 3.3.1.0
Also some things I forgot to add
2001 Civic Turbo'd
Kpro Serial # 886
I just tested this and you can set the idle target lambda to be richer than 14.59, but not leaner than that. It worked properly and I could get it to idle at 23:1 or 13:1.
Post a datalog showing the other issue.
