target afr table
mickytruelove
target afr table
Post by mickytruelove »
I am new to smanager and i am in the process of setting the target afr tables up. I have been doing this by using options>settings>target lambda.
This gives me the option for low/medium/high load but is there a way to change the value per collum for a smoother transition? i have used other other systems where i can put a different value in each cell but in smanaged it seems to just be and overlay and it changes the fuel table instead.
Am i missing something thats right in front of me?
Re: target afr table
That is the only way to set the targets. You cannot set the individual columns separately. It does interpolate between the values so there really is no problem with how this works.
mickytruelove
ok, thanks for the reply, i thought that might be the case.
crixzc
Post by crixzc »
Spunkster wrote:That is the only way to set the targets. You cannot set the individual columns separately. It does interpolate between the values so there really is no problem with how this works.
The problem is that the feature sucks.... It really wouldn't take a lot to allow each column to be adjusted individually.
