k24a2 block with k20a R head what should i do ?
py971
Post by py971 »
hi hondata:
i have some questions here.
i have a k24a2 with k20a R head on it. I know Kpro is the best way to go .but i cant find any kpro tuner around my area.
so i guess i better just use flashed ecu then run it as is ?
can i use a base rsx ecu then reflash it to k24a2 with R head spec map ?
hondata can load 2 basemaps into ECU right ?
how do i switch programs ?
thx alot
ed
Re: k24a2 block with k20a R head what should i do ?
No, this is not possible. You will need to get the K-Pro to properly tune this.
py971
Post by py971 »
Spunkster wrote:No, this is not possible. You will need to get the K-Pro to properly tune this.
hi spunkster :
if i run complete k20a R block , can i use base rsx ecu flash it to k20a R spec ? (coz i think hondata k20a map will outperf a stock PRC ecu right ? ) i want use base rsx ecu coz it with a flash will cost similer to a stock PRC ecu
No, this is not possible either. You will need to get the K-Pro to properly tune this.
