FlashProManager v2.2.8
V1.9.5 (3 Oct 2014)
  • FlashPro firmware updated to version 68
  • [RDX] Added P0234 boost cut min IAT & ECT.
  • [2006 Civic Si] Fixed datalogging MAP above 255 kPa.
  • [2006 Civic Type R] Added radiator fan control, TPS WOT determination tables, MAP to high/low error enable, and VTEC activation conditions.
  • Added 2011-2014 model TSX
  • [S2000] Fixed old calibrations loading wrong fuel pressure.
V1.9.6 (14 Nov 2014)
  • [RDX] Fixed MAP reading.
V1.9.7 (21 Nov 2014)
  • Fixed TSX AT throttle tables when converting calibrations.
V1.9.8 (24 Nov 2014)
  • Fixed recovery mode after uploading for some TSX ECUs
V1.9.9 (1 Dec 2014)
  • Fixed datalogging for the RDX
V2.0.0 (8 Dec 2014)
  • FlashPro firmware updated to version 72
  • 2012-2013 R18 Support
V2.0.1 (18 Dec 2014)
  • FlashPro firmware updated to version 73
  • [R18 2012+ ] Added launch limit
  • [TSX 2011+] Fixed datalogging from FlashPro
V2.0.3 (14 Jan 2015)
  • FlashPro firmware updated to version 75
  • [TSX 2011+ & RDX] Fixed datalogging from FlashPro
  • [S2000] Added throttle angle vs flow table.
  • [Civic R18] Added support for US 2014 MT models
V2.0.4 (15 Jan 2015)
  • FlashPro firmware updated to version 76
  • Fixed upload via button
V2.0.6 (19 Jan 2015)
  • FlashPro firmware updated to version 78
  • Fixed locking with new FlashPros
V2.0.7 (2 Mar 2015)
  • FlashPro firmware updated to version 79
  • Added Quick Support
  • [Civic R18] Added support for US 2014 CVT models
V2.0.8 (2 Mar 2015)
  • [Civic R18] Added support for more ECU parts
V2.0.9 (9 Mar 2015)
  • [TSX 2011+] Fixed high cam VE fuel tables
V2.1.0 (9 Mar 2015)
  • [R18 2014] Add support for more models
V2.1.3 (9 Apr 2015)
  • [06-11 Civic Si] Added throttle P2101 error conditions
  • [RDX] Added VSA torque limiting flag
  • Added support for 2013+ L4 Accord
V2.2.3 (15 May 2015)
  • [RDX] Fixed cylinder ignition compensation label
  • [RDX] Added factory boost limit min rpm and max ignition retard.
  • [2006-2011 Civic Type R] Added fuel consumption and fuel used datalog sensors.
  • [2006-2011 Civic Type R, 07-08 TSX] Added trip meter fuel injector size.
  • USB drivers updated to v1.0.3 (Microsoft Hardware Certified)
V2.2.6 (4 June 2015)
  • FlashPro firmware updated to version 85
  • Added 2013-15 Accord V6 support
V2.2.7 (13 July 2015)
  • Fixed problem where old software version show out of date once updated to 2.2.6
V2.2.8 (20 July 2015)
  • Test fix for 2013+ V6 Accord EGR
Download here
VitViper
Re: FlashProManager v1.9.5
Post by VitViper »
The 2011-14 TSX support, using the same FP as the previous year's TSX? Just confirming so I don't sell customers the wrong FP...
Yes, all TSX use the same FlashPro.
BEKA-BEKA
Post by BEKA-BEKA »
Does "Fixed datalogging MAP above 255 kPa" available also for Civic R18? As maximum MAP pressure reading is also 23psi, despite the actual value is more than that.
No, we did not make the same change to the R18 for the release. We have now.
the_wrench116
Post by the_wrench116 »
Hondata wrote:V1.9.5 (3 Oct 2014)
Download here
we cant see the boost pressure any more. im only able to check it on torque app for android.
Can you please elaborate on what you mean.
the_wrench116
the map/psi pictured never changes even though I can change its settings in the boost screen.
This will be fixed in the next beta release.
the_wrench116
thanks. can't wait.
J.Dre
Re: FlashProManager v1.9.7
Post by J.Dre »
I'm not sure how to explain this, but the completion of the upload of a calibration is different with 1.9.7. The ECU used to make a sound, as if it were restarting, when the upload is complete. The 1.9.7 beta does not do this. It causes additional dings/warnings to go off after the calibration is done uploading.
Was this changed? Or is something wrong with the upload process (to the vehicle) with 1.9.7 beta?
For what vehicle? Does it ask you to cycle the ignition?
J.Dre
Post by J.Dre »
Hondata wrote:For what vehicle? Does it ask you to cycle the ignition?
'13 Civic Si. I follow the same process as always. I went from 1.9.3 to 1.9.7 (beta) - firmware upgraded.
With 1.9.7 (beta), when the red light stops flashing on the FlashPro, the ECU does not make a sound (like it used to with the previous Firmware) and now more warnings/dings go off - multiple warnings, including ABS, etc. So, I don't know if the calibration is being uploaded or not. I did it two times in a row just to make sure, but the upload process seemed to be messed up.
With 1.9.3, I would hear the ECU restart and that would indicate the upload was successful. No warnings/dings after that, only during the upload.
How are you uploading? From the FlashPro using the button or with a laptop?
J.Dre
Post by J.Dre »
Hondata wrote:How are you uploading? From the FlashPro using the button or with a laptop?
The FlashPro device.
