[NOVICE QUESTION] What ECU should i buy?
vascorama
Post by vascorama »
Hello all, i didn´t find a specific area on the forum for general questions, so i had to post here, sorry for that.
I have a 2000, 2.0ies Honda Accord, F20B6 engine and i´m all alone in the internet because i can´t find what ECU should i buy, not even on hondata website my model is listed...
I´m quite sure i must not be the first person in the world with this question, so my post has the sole meaning of maybe, i´ll find someone who knows about it.
Before you ask, the purpose is to fit a turbo on it.
Thanks in advance
Re: [NOVICE QUESTION] What ECU should i buy?
vascorama
Post by vascorama »
It´s a manual transmission, euro version of the accord, like this one: http://bit.ly/1rff3Qj
Thank you
edit: my plate says my car is from year 2000, but i´m almost sure it was made in 1999, i saw that somewhere in the car...
To use a Hondata system, you will need an OBD2 to OBD1 adapter and you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
Your engine also probably has a 3 wire idle controller which will have to be swapped to a 2 wire idle controller with an adapter plate.
vascorama
Post by vascorama »
Hello ant thank you for your help, but i need a bit more if you can help me...don´t get me wrong, it´s just that i´m in a new world, and theres no info(if it was a civic vti i wouldn´t come to the forum, plenty info out there).
I wouldn´t mind paying a person to fit a Hondata on my car, the problem is i don´t know anyone on my country capable of doing that job, there may be some, but they are hidden...
Can you pinpoint me the exact list of material i need?
Another question, when i fit that ECU, the car will run or do i have to create a map?
The manifolds and mechanical parts are the least of my problems, i´ve done that a few times(on diesel engines with mechanical fuel pumps), it´s just this ECU thing that is in a world i never visited before.
Thank you, and once again thank you very much for your patience.
You will need to start from one of the existing calibrations and tune from there.
vascorama
Post by vascorama »
Can you send me the links to the material i need?
Thank you
