kpro S1 wideband not working,batt voltage between pins A1A24
madaxgt
Post by madaxgt »
The wideband is wired in as per the hondata wiring for k20. I get a sensor heater wiring malfunction DTC P1166. I checked the service manual and the first thing it says to do is check voltage between A1 and A24 and if there is battery voltage then a new ecu is needed? I have battery voltage but surely that is correct as it means current is flowing to the o2 heater relay coil as A1 is AFS HTC.
Re: kpro S1 wideband not working,batt voltage between pins A
What is the part number of the ECU?
madaxgt
Post by madaxgt »
37820 PRB A06
2068-000025
If the Factory service manual tells you this means the ECU is damaged, then it probably is.
madaxgt
Post by madaxgt »
great, its hardly been used and all wired correctly. What are my options?
Have you tried the ECU in a known working vehicle to see if it has the same error?
madaxgt
Post by madaxgt »
No but I could send it to a friend to test who has a k pro car. I will try that first.
madaxgt
Post by madaxgt »
does the lambda heater relay have to be a solid state relay or can it be a std relay? I used the std relay pack main, fuel and what I think is the lambda relay from a dc5 integra.
