hondata problem
matheusorlandini
hondata problem
Post by matheusorlandini »
the problem is that first my ELD sensor fail. then i had it changed, and after that, when i plug the hondata to the OBD2, the check engine flash, and the odometer display is also flashing. the engine runs strange and there is no DTC codes.....
if i just take the hondata out everything come to be normal again....
serial # FP-SI-US-16510
stock civic si fa5 with inbox air filter and cat delet.
Re: hondata problem
From Help, About, what version of software are you using?
