Electronic boost controller to P75 OBD0-1 converted.
PR8urvtec
Post by PR8urvtec »
I'm using Hondata S300 on a 1990 Integra. It's converted to OBD1 with a RyWire conversion harness. I'm trying to install the MAC solenoid but having trouble with the wiring.
The wiring instructions call for the MAC solenoid to be wired to pin A11. I don't have a wire on the jumper harness at pin A11 and can't seem to find a corresponding wire on the OBD0 plugs. Do I need to add a pin at A11 for it to work or is there another pin I could use?
Re: Electronic boost controller to P75 OBD0-1 converted.
If there is no pin, you will have to add one.
PR8urvtec
Post by PR8urvtec »
Cool. Thanks for the response. Boost is going up this weekend!!!
