Is this normal AFR for cold start?
munro88
Post by munro88 »
Are these AFRs normal for a cold start?
Stock ITR base map for a STOCK ITR (aussie 11:1 CR) with I/H/E
not sure why columns 7 and over have light up when i didnt take the car over 1600rpm, in my drive way (touched the throttle slightly)....
originally pulled codes 13 and 16 - so disabled fuel injector error and barometric pressure sensor. codes gone, will this effect the car's driveability ?
I am not using a wideband until the dyno so it is reading off stock o2 sensor.
Re: Is this normal AFR for cold start?
Ignore those readings since you do not have a wideband, they are not going to give you any real data.
If your ECU does not have the circuitry for those things then you must disable the errors.
munro88
Post by munro88 »
Thanks for reply. Is it safe to drive to see that no more codes come up?
That I could not tell you since there is no way to see the actual AF ratio.
