2006 TSX At to MT Conversion
rherman_63
Post by rherman_63 »
Hello Hondata gurus...
I own the 06 AT and want to swap in an MT. Can I use the AT ECU, Dash and Engine Harness? Can I chip the AT ECU to ignore any errors or weird shift communique?
Or do I need the MT ECU, Dash and Engine Harnesses and immobilizer?
Thanks in Advance...Not a lot of info on this out there.
Re: 2006 TSX At to MT Conversion
I'm not sure what all would be involved, but there is nothing you can do with the 06 ECU you have. You would have to use an 07-08 ECU to use the FlashPro and you should use a manual version if you plan to do this.
rherman_63
Spunkster wrote:I'm not sure what all would be involved, but there is nothing you can do with the 06 ECU you have. You would have to use an 07-08 ECU to use the FlashPro and you should use a manual version if you plan to do this.
Alright, thanks for the info Spunkster.
