Kpro VSS question
jgor
Kpro VSS question
Post by jgor »
Hi, I have a quick question. Will KPro work without a VSS hooked up?
2005 RSX-S, w/ TSX K24 swap. 2004 RSX wiring harness, 2004 RSX ECU w/ KPro,
Original 6 speed transmission from 2005 RSX-S, but transmission was modified for racing, (road course), and VSS internals are missing from transmission. Vehicle has no dash, gutted, track only use. Thanks,
Re: Kpro VSS question
No, you will have problems with VTEC and VTC activation.
Cashmo
Post by Cashmo »
Not sure how different your situation is compared to my K20A2 with a Toyota T40 trans on it. Under the MISC tab I use "No Speed Sensor", Closed Loop is always off, under VTEC the "VTEC oil pressure switch enabled" and "VTC (iVTEC)" options are checked. Min speed for VTEC operation = 0. You can get creative with the Onboard Datalogging options too.
