cam command and cam problem
blkkseries
Post by blkkseries »
MODS:
Full bolt ons (SRI,70mm TB, Manifold,RH,E), kelford stage 2 (179-b) cams with supertech valvetrain( dual valve springs), supertech nitrate coated valve stems, 87.5 12.5/1 supertech pistons, k1 lightweight rods,rdx 410cc injectors, k20 modified oil pump, coolant bypass
Made 250/193 @9k dynojet (k20z1 head/k24a1 bottom) in a 06 rsx type s...
just completed my k20/24 build n im at a lost as to whats going on. During the 500 mile break in the vtc solenoid broke. I replaced it but there was a ratcheting sound in the morning or after long periods of sitting. I replaced the oem tensioner but that didnt solve the problem. I just replaced the VTC gear and I didnt hear the sound this mourning but the cam command and what the cams are actually doing are off. They've been off since I changed the vtc solienoid and the tensioner . What could be the problem? I checked oil pressure n it was good. Timing is on . Im not throwing any cel vtc phase gap codes. I think the oil filter that was used to break the motor in is different then the regular filter that im using idk..any help is appreciated.
At a stand still if I rev the car to 3k rpm n let off the accelerator the car dips then stalls
Clif:
just built k20/24
Replaced vtc gear , solenoid, timing chain tensioner
Checked timing, valve lash , oil pressure
problem: cam command n what the cam is actually doing is off by 6 degrees at least in some places
Re: cam command and cam problem
Have you replaced the chain?
blkkseries
I have to measure the distance by the tensioner to make sure its in spec...would chain stretch happen so quickly?
What is the serial number of the K-Pro board inside the ECU?
blkkseries
Id have open it up and see. Is there any other place I could look? I bought it from a authorized dealer...is it possible for the car to be on time by the crank but off at the cams?
You will have to open the ECU to get the serial number that is on the K-Pro board itself. Anything is possible.
