Integra ABS Sensor Wire
august77
Post by august77 »
Hi..
I found 4 ABS sensors from a 97 Honda Integra and there are two wires coming out from the sensor. White and Blue. How do we test the wires, to see if they are positive or negative?
Planning to use these sensors for the Hondata Traction Control.
Re: Integra ABS Sensor Wire
I'm not sure of the wire colors on the sensors themselves. I always tap the wires at the control unit for the ABS and the wire colors there are different. You will need to look at the factory service manual to check what the colors are for each sensor.
ej1_ex
Post by ej1_ex »
go to traction tab and click reference
