Analog Input? How to datalog methanol injection engagement?
jomo
Post by jomo »
Is there a way to datalog the on/off engagement of methanol injection?
Currently, I have methanol injection to engage on an independent boost switch, but I want to incorporate it into Flashpro. Since there is no apparent feature to control methanol injection such as nitrous control in K-Pro, is there at least a way to monitor when methanol engages so I can view it in my graph?
Just a thought-- I'm already using the EGRL input for a wideband input. Are there any other inputs available?
Any ideas/suggestions are greatly appreciated.
Re: Analog Input? How to datalog methanol injection engageme
There really is no easy way of doing this as analog inputs are 0-5v and the injection kit will be 12v.
shind3
Re: Analog Input? How to datalog methanol injection engagement?
Post by shind3 »
You could just switch to a manual boost controller and use your current boost control solenoid driver to run a MAP vs RPM ADI map. You would need support from Hondata to do so though, so good luck with that. lol
