ECU not Live
Dondada03
ECU not Live
Post by Dondada03 »
my battery voltage is very low, i am using a rbb a71 ecu in a 2004 cl9, when i switch my car to ignition the fuel pump wont prime and the immobilizer light keeps flashing. when i plug in my flashpro it does not pick up the ecu. however the radio works and the lights etc. is my ECU dead?
Re: ECU not Live
You should start by either replacing or charging the battery and see if that resolves the issue.
Dondada03
Re: ECU not Live
Post by Dondada03 »
i placed a fully charged battery in the car and the immobilizer light keeps flashing and the fuel pump wont prime. can you explain what is wrong>
Dondada03
Re: ECU not Live
Post by Dondada03 »
additionally the ecu has the x not to it all of a sudden
Re: ECU not Live
The key an immobilizer must be matched by an Acura dealer.
Dondada03
Re: ECU not Live
Post by Dondada03 »
This ECU was functional before in me car along with flashpro. It was already paired with the immobilizer
Re: ECU not Live
Check your fuses. Since this sounds like it is in a unsupported vehicle it is hard to say what could be wrong.
Zoro2006
Re: ECU not Live
Post by Zoro2006 »
Dondada03 wrote:This ECU was functional before in me car along with flashpro. It was already paired with the immobilizer
I have seen that ECU sometimes looses "pair" with immobilizer when it's paired with not original Honda equipment.
Suggest you to re-pair immobilizer with ECU using Honda dealer equipment.
Known as Vaikis_
