Flashpro not detecting ECU ?
vtec4life
Post by vtec4life »
I have a 2012 si, i was resetting ecu to stock so that i could unlock flashpro. In the process my ecu went in to recovery mode, so i uploaded a stock calibration and it worked fine. So I re attempt to reset ecu to stock and this time instead of recovery mode flash pro shows obdi connected and ecu not detected ?? I checked battery and the positive cable was loose... so im not sure if ecu is fried or fuses? Need help thanks
Re: Flashpro not detecting ECU ?
Check all your fuses. You could also try your ECU in a different vehicle to see if it might be a wiring issue.
