Euro S2000: L.trim value unclear
Peter Wortel
Post by Peter Wortel »
After installing FPM 1.9.5.0 my longlasting problems with low AF-values were solved, because of the wrong fuel pressure. In a new datalog however I noticed an L.trim value which is getting lower all te time, while the S.trim value is reasonable steady, in my opinion. Can you explain the L.trim value starting of 0 and ending at -17 in my datalog?
Flashpro Serial# FP-S2K-INT-40023
Euro S2000 2006 Supercharged
FPM 1.9.6
Re: Euro S2000: L.trim value unclear
I do not believe that the Euro S2000 uses long term trim. In that case it will change, but have no effect on the fuel.
Peter Wortel
Can you publish a list of FPM differences between the US-S2000 and the Euro-S2000?
