PLX Boost digital input into S2000 Kpro III
pipka76
Post by pipka76 »
Hello Hondata,
I'm struggling with correct setting with my PLX boost sensor input, which I have connected through KPro III digital input. I have PLX AFR and boost sensors in the chain and AFR is read just fine. AFR is my DI0, boost DI1.
I have two issues with DI1 (boost):
- KPro reads boost values in the strange scale (not linear), for example: MAP sensor reads 17.24psi and DI1 reads 971,75psi or MAP 20,06psi - DI1 1841,98psi.
- KPro reads only when there is a boost (when vacuum, then it reads zero)
Please find screenshot of my digital input setup attached.
Please suggest. Thanks.
S2000 Kpro III PRA
Re: PLX Boost digital input into S2000 Kpro III
How exactly do you have these wired? Is the terminator installed? Where is the terminator installed?
pipka76
Post by pipka76 »
Yes, the terminator is installed and it is in the boost sensor module only.
The chain is like this:
boost module (with terminator) TX => afr module' RX (no terminator), then afr' TX => KPro digital and DM-6 gauge (y cable split)
DM-6 gauge shows vacuum/boost values just fine.
Post the calibration as well as a datalog showing the issue.
pipka76
Post by pipka76 »
Calibration and datalog attached.
Thanks.
Try connecting just one digital input at a time and see if that works.
