K-Pro and B Series MAP sensor
kmvguy83
Post by kmvguy83 »
If I use B Series MAP sensor what parameter do I have to use in order to make this work?
Re: K-Pro and B Series MAP sensor
Internally the B and K series MAP sensors are the same. You don't need to change anything.
kmvguy83
Post by kmvguy83 »
Thank you for the reply! So I shouldn't have problem using b series MAP sensor, right?
They're the same electrically, but I would not go as far to say that you're not going to have any problems, as obviously you're doing something strange. I'd only ever use the K-Series MAP sensor on a K-Series engine.
kmvguy83
Post by kmvguy83 »
I'm doing a k swap on a Miata using s2000 manifold since normal k series manifold ends up intake port on firewall side.
I have s2000 manifold with 70mm Tb.
More info and build thread here.
http://www.k20a.org/forum/showthread.php?t=174081
What if I use b series 4 bar hondata map sensor?
Would that be a better solution?
