KManager difficult to use/see since 4.0.6
NtegraDryvr
Post by NtegraDryvr »
Ever since I updated from KManager v4.0.4 to 4.0.6 the display and layout is all messed up. Take a look at the attached screen shot. I am running a 3200x1800 resolution on my brand new laptop which is VERY helpful when tuning since I can fit everything on the screen (and the reason I bought it), but not anymore! I was going to reinstall v4.0.4 but can no longer find it. No display settings or any other settings on my computer have changed, this happened as soon as I updated. It is most obvious in the screen shot when you look at the menu. Also the slider for the IACV is missing entirely.
I am running Windows 8.1, but I doubt that is relevant. Thanks!
Re: KManager difficult to use/see since 4.0.6
If you change the resolution, does it appear normally?
Can you also post a screen shot of the help, about screen (which should show the screen dpi)?
NtegraDryvr
Spunkster wrote:If you change the resolution, does it appear normally?
Changing the resolution doesn't change how Kmanager is displayed it just makes everything larger. However in display settings I can change the scaling that is built into Windows 8 and turn it down to an unusable 125% like shown here. I run at 200% which has been a perfect setting up until the update.
Hondata wrote:Can you also post a screen shot of the help, about screen (which should show the screen dpi)?
It seems to only look correct around 120dpi within Kmanager/about which is only achieved at 125% and probably 100% scaling which isn't usable.
Thanks, you've answered my question which is what your display scaling is set at. We'll look at it now.
NtegraDryvr
I have another question/issue as well which I can start another thread for if need be.
I run ALOT of water meth. I don't know if this has always been an issue or if I am only noticing it now that I am spraying so much methanol at once to keep my overspun m62 cool. When lean protection engages and pulls fuel from the injectors the nitrous controls still stay active and spraying water meth which is just enough fuel for the motor to keep running however extremely lean thus defeating the purpose. Can you guys look into this for me? Thanks
