Kpro4 and AIM / Racepak Dashs
Liwijatan
Post by Liwijatan »
I’ve just bought a Kpro4 with installation kit for the S2000. I have seen it’s possible to wire up directly a AIM MXL or Racepak IQ3.
Is the Dash just enough or do I need some “box” for example the AIM Evo4 or similar.
I don’t need the logging functions or anything. The Dash is just a replacement for the gauges. I’m running a S2000 engine in a Westfield seven and the original S2000 is not that good (Water resistant, sun glare and so on). So my goal would be to keep the budget as low as possible. The Evo4 for example is more money then the dash.
Also I would like to add oil pressure and temperature sensors.
Thanks for your help.
Re: Kpro4 and AIM / Racepak Dashs
Liwijatan
Post by Liwijatan »
I did still not pick a new dash and not sure what to buy. I want to get rid of the stock instruments (s2000) and don't want to spend too much bucks on that topic.
What I've understood, I can buy a AIM Dash configure it to Honda and the Kpro to Aim using the CAN. So I just need the stock AIM Dash and no special modules?
Kpro is working without buying modules and stuff with AIM MXL Strada, right?
Can it also work with AIM MXL Dash (most basic version)? It's a bit cheaper?
And is Kpro also working with the new AIM MXS Strada (color tft)?
Thanks very much for your. I'm really confused.
Br,
Sebastian
The KPro4 has both a serial and CAN output which AiM dashes can use. We've tested with the MXL and it works. It should work with other AiM dashes if AiM supports the same protocols, but that question is for AiM, not us.
