2006 green connector CAN adapter
lonewulfs919
Post by lonewulfs919 »
I have an 06 Tsx 6 spd with navi, which I'm not sure if I connected the cables on the green connector right. My green connector looked nothing like the one that was shown on the illustration. There wasn't a brown wire to the far left,instead there was a yellow to the far right. What I did was connect the wires on the top row on the 2nd, and 3rd input. Does that sound correct? I need help ASAP before I take the car to get my ecu programmed. Thanks in advance!
Re: 2006 green connector CAN adapter
Can you post pictures of exactly what you have connected?
lonewulfs919
Can't see it clearly but, on the very top row placed the wires on the 2nd and 3rd position.so it looks something like : top row 1st position blank, 2NDn and 3rd can wiring, 4th position there's a yellow wiring.
Have you tried connecting the ECU and FlashPro to see if it can see the ECU connected? That will be a really easy way to tell if it is wired correctly.
sky200
Post by sky200 »
Hi,
I attempted to do this today and I believe I came across the same issue.
I also do not see a single brown wire on the far left, but only a single yellow wire on the far right.
Should I go ahead and proceed with inserting the red and white wire on slot#2 and #3 anyway?
Also any tips on accessing the connector? Space is very limited =(
Thanks for your help.
jayphalla
Post by jayphalla »
Hey guys,
Hope you guys were able to the issue. Recently purchased flashpro for 04 TSX, and came across the issues of the top slot having a yellow/red wire on the far right. The rest of the slots in that top row are blanks.
How did you guys over come the problem?
Thanks,
Jason
You will have to post a picture showing this.
Hondalove42484
Post by Hondalove42484 »
Hello, I have a 2006 TSX 6 speed w/navi, and I came into the exact same harness. I believe since the instructions say the top 5 slots all are linked together,and the can hi/lo should be able to plug into the topmost connector since it has just the yellow wire coming out the #4 pin. Seems nobody knows of this, I am going to test the # 2 and 3 pins to confirm, there should be a 2.5 volt difference between them when they are transmitting data. But if anyone knows for sure, please let me know, thank you all
Hondalove42484
I ran into the same issue on my 06 USDM TSX 6spd, and tested the top connector slots 2 and 3, they tested what a CAN high and low should test for voltage, so in the next few days I'll have an answer when I run the jumpers to the DLC.
Hondalove42484
The answer is yes, the middle two pins are CAN HI/LO, for all the people whom have encountered this harness with one yellow wire coming out the top right pin. Sorry for the late response
