K Swap - Compatible Sensors
KSeries4Life
Post by KSeries4Life »
Hello, I'm working on a k24/k20 swap currently and had some questions on a few sensors that would work with my K Pro V4 ecu (RSX 02-04 type s version). I realize it would be best to just get all 02-04 RSX type s sensors, but it seems that K Pro works in a variety or k-series engines using different sensor part numbers.
First is the knock sensor. I have access to one from a 2004 S2000. Know if this sensor would give K Pro correct readings for this engine?
Second is the crank sensor. What I have currently is from an 08 TSX and wanted to see if this would work. Looks like the previous owner of my used RSX engine harness converted the plug over to this style crank sensor.
Re: K Swap - Compatible Sensors
The S2000 knock sensor will work.
The K24 crank sensor will work electrically, but the pinout is different from the K20. This is probably why the previous owner switched connectors.
