92 integra no ELD in d10 and plx sm-afr power issues.
mikel58
Post by mikel58 »
Hey guys, I'm following the hondata plx installation instructions and found no wire at d10 ELD to cut on my 92 integra. Anyone with a 92-93 DA that noticed this? I added a wire to the ecu harness in d10.
The next thing is that i figured I would check the gauge before I ran the wire behind my dash. I grounded it to the thermostat housing and power from the ACC slot in the fuse box. The gauge got no power. So I switched the power for my oil pressure gauge and the plx gauge and my oil pressure gauge turned on. This might be a retarded question does d14 and d10 wires need to be plugged into the module box as well for the gauge to get power?
Re: 92 integra no ELD in d10 and plx sm-afr power issues.
The inputs have nothing to do with the device getting power. You should use a multimeter to check continuity and to make sure the locations you have are good power and ground locations.
mikel58
Post by mikel58 »
Power location is fine. And I used the same ground spot on the thermostat housing but I'll check the ground when I get home. Can I use the car battery to test it? Or would that do damage?
You can use the battery, but you should use a fuse in line.
mikel58
Post by mikel58 »
I got it. The audio looking cable was not plugged in -_- thats why it was not turning on. Thanks for your help.
