Running innovate a/f as standalone wideband s300
mickyfick
Post by mickyfick »
I'm using the innovate wideband as a standalone 02 sensor, the problem I'm experiencing is if the car is warmed up and I go to start the car it usually has a problem starting/ idling until the O2 sensor has warmed up and is sending a signal to the ecu (usually about 25 seconds). Afterwards idle is fine no problems.
Is there a way to program the s300 to not look for 02 signal or read a programmed fuel table for only 30 seconds.
This is usually not a problem for me except when the car is warm. Usually ends up in a lean condition which is causing me some grief.
Any input appreciated
Re: Running innovate a/f as standalone wideband s300
No there is no way to set a delay like that. This could be a tuning issue as this is not a common problem. Has this been tuned on the dyno by a professional?
AREA876
Post by AREA876 »
Monitor your fuel compensation for air temperature at warm restart and adjust accordingly.
