Application Error: Event 1005 (Error)
typer86
Post by typer86 »
Hi,
I can not start the Hondata Application FlashProManager on my both PC's after installation of the software.
The Hondata Flash Pro device will be detected - OK
Total strange is, the same error comes up on my old Windows 7 backup system.
Details of my current system:
HDD (SSD) #1: Samsung SSD 840pro - 256GB - overprovisioning active (system drive)
HDD #2: WD 1TB (data drive)
OS: Windows 8.1 pro
RAM: 8 GB
CPU: i7 4700k
Virussoftware: Avast Free Antivirus 2015
Firewall: Windows Firewall
PC #2: (Backup PC!!)
HDD (SSD) #1: Samsung SSD 840pro - 128GB - overprovisioning active
HDD #2: WD 1TB
HDD #3: Samsung 500 GB
OS: Windows 7 pro
RAM: 4 GB
CPU: Q6600
Virussoftware: none
In the Windows Logfile I can only find the following entry:
Description
Windows cannot access the file for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer, or the disk is missing. Windows closed the program because of this error.
Program:
File: C:\Program Files (x86)\FlashPro\FlashProManager.exe
The error value is listed in the Additional Data section.
User Action
1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
2. If the file still cannot be accessed and
- It is on the network your network administrator should verify that there is not a problem with the network and that the server can be contacted.
- It is on a removable disk for example a floppy disk or CD-ROM verify that the disk is fully inserted into the computer.
3. Check and repair the file system by running CHKDSK. To run CHKDSK click Start click Run type CMD and then click OK. At the command prompt type CHKDSK /F and then press ENTER.
4. If the problem persists restore the file from a backup copy.
5. Determine whether other files on the same disk can be opened. If not the disk might be damaged. If it is a hard disk contact your administrator or computer hardware vendor for further assistance.
The Checkdisk didn't find any problem. PC works fine.
All drivers and Bios versions are up to date.
All Windowsupdates are installed.
No other problems with other applications.
Please note the backup system is only for Hondata so no other Apps are installed. And I have the same error.
Reinstallation to a other Partion same Error.
Maybe a Windowsupdate block the Flashpro Application?
Please help!!
Re: Application Error: Event 1005 (Error)
Re-download and install FlashProManager
Avast may be causing the problem on the first computer.
typer86
Post by typer86 »
Same Error with the Beta version.
In my case I fixed the problem to install virtualbox and installed a fresh new Win 7 OS without any OS updates. Unplugg the virtual net card.
Install flashPro manager = OK
FlashPro manager start = OK
Hondata USB connection enabled in the vbox = OK
This is a little workaround for me.
I think I must re-install my OS to fix the problem. I don't know why... :(
Regards,
