ID 1300 injectors
S2000443
ID 1300 injectors
Post by S2000443 »
I have an 06 s2000 rotrex supercharged with ID 1300 injectors. I downloaded the supercharger map and then added the iD 1000 injector data and the car started fine. Why is it that when I import the iD 1300 injector slope and offset voltage data into the map the car will absolutely not start. Am I missing something here? Can you please post up what values to input so I can start car. I also think it is time for a new 1300 cc injector base map since these are getting more popular
Re: ID 1300 injectors
What values are you using? Can you provide the calibration?
To begin with I would suggest using the current (1000cc) calibration and just changing the injector size to 1300cc.
