PRA no start engine
Ant06ka
PRA no start engine
Post by Ant06ka »
hello
I have a problem with starting the engine. When you turn the key, the pump is pumping. And then you start to plant, and the fuel supply is interrupted for approximately 5-10 seconds. If you keep pedalt gas can during this difficult time to start. After 5-10 seconds, everything works fine. What could be the problem?
ECU Kpro PRA.
Re: PRA no start engine
Has this been professionally tuned?
Ant06ka
Post by Ant06ka »
Yes, tuned properly, I think) After 10 seconds everything works fine and without problems, the only problem starting the engine, and we think in the short-term failure of fuel. The machine is the way civic es1 7gen d15b non vtec JDM. Put firmware PRA d17 non vtec and corrected it.
We don't support the D17 engines in European vehicles(non-USA). This could be part of the issue you are having.
Ant06ka
Post by Ant06ka »
European cars can differ only pin connections. If I show you my pinout, you can tell me, can that is not on the spot, or something not.
Applications
•2001-2005 D17 Civic DX, LX, HX & EX Manual transmission only (North American vehicles only)
Ant06ka
Post by Ant06ka »
I have a 2001 Civic manual transmission, the engine now D15, D17 will set later. But depending on the engine is no. tomorrow will show you my pinout, can see what is wrong. I ask you to look at a small request, and can you see what's missing.
I'm sorry, but this is not supported for this exact reason. If you wish to discuss the problem with your dealer you can, but it is not something we can help with.
