B18 ITB base tune
leeg1990
B18 ITB base tune
Post by leeg1990 »
Hey, just after confirmation of which of the config's built into SManager I should use as my base map.
I only need it so I can start the car to bleed the cooling system and make sure it's all working before trailering it to be tuned.
Car is a JDM 98' ITR, standard engine with ATPower ITB's and 440cc injectors. IACV removed. Management is Hondata S300 v3
There's a tune in there for an LS running ITB's, but I'm just thinking id be best to use the "ITR-stock" base map with the "Disable IAC error" checked.
Thoughts?
Thanks, Lee.
Re: B18 ITB base tune
You will have to try and see which one starts and runs best in your situation.
