KManager API
Friendly
KManager API
Post by Friendly »
I was wondering if KManager had some sort of API available so I can use some of the sensor data in a custom script.
Or if KManager somehow allows custom scripting for displays.
Reason being is that I would like to display MPG. I found a way to make the calculations using the INJ(ms), VSS(mph), and RPM.
Is it possible to perform these calculations within KManager and display it to the the display?
Re: KManager API
Friendly
Re: KManager API
Post by Friendly »
Thank you for the reply.
I was able to read the page and modify the excel sheet to accept incoming data from KManager instead of SManager and make the calculations for MPG, however I am unsure how your example DDE server works.
I noticed the example one was made for SManager. I was trying to modify the exampleDDE.exe to read from KManager but I wasn't sure how to make the modifications or how I would recompile it.
Do you by any chance have an exampleDDEserver for KManager or can you provide me with a link to help me modify the one you provided?
Thank you very much again!
Re: KManager API
What language are you going to use for your display? Almost every language should have a DDE example.
The example in google code compils using Dev-C++ http://orwelldevcpp.blogspot.com/, but should compile with MicroSoft or other compilers.
For a really quick change get the example exe and hexedit smanager to kmanager in the binary.
Friendly
Re: KManager API
Post by Friendly »
I was planning on using VB for the visplay.
As for the example. I was able to open it up in IDA and change the SManager to KManager which seems to let it start up without any errors. However during my testing I noticed that it was not updating the values.
I was using a datalog to do this and letting the cursor run through the entire log. Does it work using this method or does it only work from a live stream?
Re: KManager API
It updates from a live stream only.
Friendly
Re: KManager API
Post by Friendly »
Thank you so much,
I was able to get it working and now my MPG seems to be working just fine.
Here is the formula I am using to calculate MPG if you are curious:
=ROUND((B18 / (((60 * (4 * (310 * ((CONVERT(IF(A13 = 0, 0.001, A13),"sec","mn") * B17) / 2)))) / 1000) / 3.78541)), 2)
A13 is the Injector Pulse Width (INJ) in seconds.
B17 is RPM
B18 is MPH
I am using INJ because my car does not have a MAF sensor.
This formula wont be accurate for boosted vehicles as it assumes constant fuel pressure (1:1).
Would it possible to see a MPG option in a future release of KPRO? I would love to see it on my display especially for long drives.
