Need Advice on Which Calibration to Run - 2011 Civic Si
Azulux
Post by Azulux »
Hi all,
I've got a 2011 Civic Si, currently on the stock MAP tune but will be putting Hybrid Racing Intake and Full Race Exhaust on soon. I was wondering what calibration I should run for the time being before I get a custom tune. I can't find any map calibrations for just intake and exhaust but I can find calibrations for intake, header, and exhaust - would I be ok running that even though I don't have a header? If not, I'm not sure what other map calibration I can run with this setup (intake & exhaust). Any and all advice and recommendations/suggestions are welcome! Thanks!
Re: Need Advice on Which Calibration to Run - 2011 Civic Si
There will be no way to tell if is safe until you install the parts and datalog to see what the AF is and check for knock.
MorningStar
Post by MorningStar »
I know its a little late but no don't run that calibration. There will be no benefit from it it may also cause you to lose power cause its not tuned correctly. Always tune for what you have to get the most of each mod or stock part. I would honestly start custom tuning it since you already plan it it an that there is no base tune for your set up
